using an ip address to open database
I created a database on a seperate computer and am using a network to connect to the database. I want to use labview to store data on this network. I have the database connectivity toolkit =, but do not now how to use an ip address to open a database connection. can anyone help with this?
Ray
(2,779 Views)
The DB toolkit works with ADO which requires that you use a connection string.
You can do this in one of two ways: either create the string yourself (the format depends on the database you use and can be found online) or use the built-in Windows interface by creating a new file with the UDL extension and then double clicking it. If you have the correct software installed, this should open a wizard you can use to set up your connection. You should then be able to point to that UDL file to open your connection.
There should be a couple of examples which come with the toolkit. You should be able to find it in the Help menu or in the example finder (Help>>Find Examples).
___________________
Try to take over the world!
(2,763 Views)
Thanks, tst!
Amanda Howard
Americas Services and Support Recruiting Manager
(2,737 Views)
