using boolien switches for case selection
Hi all,
        i want to use boolien switches for case selection in triggered mode. i mean i have a 4 switches (trigger mode as latch when pressed) when i have pressed and released the button a case corresponding to the switch has to be executed, but the case structure is able to work only with ring selectors, and single swiches(but not with  combinations of different states). i tried with combinational logic gates but it incresed the complexity nothing else.
               some body help me to do it.
Message 1 of 8
(5,627 Views)
Accepted by topic author chaitu2
You can use the boolean like this
Message 2 of 8
(5,622 Views)
Hi Chaitu
make an array out of your controls and then convert the resulting boolean array to a number, Use that number to control the case structure.
Best Regards
David
NISW
Message 3 of 8
(5,621 Views)
thanks muks it worked
Message 4 of 8
(5,617 Views)
Explaining what David mentioned:
To get the radix (b), right click on the number and select 'Radix'
Ton
My LabVIEW Ideas
Message 5 of 8
(5,615 Views)
This approach lacks in naming the buttons. Elements within arrays share everything except the value (which could be different in each element). Since "Boolean Text" is an attribute of the button, it willl be shared for all other buttons.
Therefore, it is suggested to use a cluster of buttons and convert it to an array in software:
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 6 of 8
(5,604 Views)
hope this helps,
Norbert
Provided the number of boolean values (bits) are limited to something less than 8, casting as an enum allows descriptive case names.
Ben
Message 7 of 8
(5,592 Views)
Ben,
nice hint. The only disadvantage i think of is that there is the enum and on the other hand the cluster: What if one component is changed??
just pondering,
Norbert
[Edit] I just re-thought  (english word??) the sentenced you marked in bold. Of course i talked about the text displayed on the buttons on the frontpanel.
Datenhaltung boolean Array.PNGDatenhaltung boolean Array ändern 1.PNGDatenhaltung boolean Array.PNG
Message Edited by Norbert B on 12-01-2009 09:56 AM
Norbert
Expert: Geometry
Message 8 of 8
(5,578 Views)
