using cRIO chassis slots for general-purpose
hi,
i have cRIO 9004 and cRIO 9103 chassis, labview 2011...
as i know, cRIO chassis controls its slots if there present any module or not.. if detect anyone, read EEPROM and so on..
but how can i control cRIO chassis slots for my own general-purpose without any module...
when i create projects, it just shows me as chassis I/O
* chassis Temperature
* FPGA LED
* Scan Clock
* Sleep
* system reset
i couldn't write anything from chassis slots and see on oscilloscope screen, (for example: using as analog or digital output) ...
Davut..
(2,888 Views)
Well that's because you can't do that without use of "custom development kit"
http://sine.ni.com/nips/cds/view/p/lang/es/nid/14548
Every slot isn't standard i/o, these manage certain bus of national intrument, and if you try use then will have to create a circuit and program a driver.
Regards
(2,882 Views)
thanks for your reply
in fact i have...
-module development kit 2.0
-compactRIO module support 4.0.1
-NIRIO 4.0
i know which pins i can use for DIO or etc..
the point is, i haven't thought that it is not possible without hardware.. i read the manuals but couldn't create all structure in my mind..
So, as i understand from your message, i have some programs but it s not possible to controlling chassis slots without hardware.. am i right?
(2,873 Views)
Accepted by topic author davut
Try to follow the steps like you will create a new module. Like in this example, but jumping the circuit part.
http://zone.ni.com/devzone/cda/tut/p/id/7868
(2,866 Views)
