using case sequence
Is there a way to use the same case for two different value ?
case1  : 2 or 8
case 2 : Default
in C :
if (x==2 || x===8 )
else
(2,748 Views)
Yes, that's no problem. You can set special values (2,5,7 -> commaseparated), and you can also set ranges (5..10). You can also set open ranges (10..) which means all values >= 10.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,746 Views)
(2,741 Views)
