Hi there,
Its been a while since I did this, but if my memory serves me correctly there is no way to specify which NIC to use, but its defined by the IP address you try and connect to.
So as you have two different subnets, then LV or the Windows TCP/IP stack is smart enough to direct traffic to the correct net adapter?
In your case can you open two TCP connections, and just switch transmission to the other connection if a failure is detected?
nrp
ps: it was a while ago, my memory may be completely wrong!
