using event structure problem
My program structure is there is a event structure inside a while loop. I want the program check equipment status when no event occurs. How can I put this idle in my program?
Thanks.
(2,851 Views)
Create a "timeout" event and wire a reasonable timeout to the timeout terminal.
Check your equipment inside the timeout event case, which will execute whenever the wired timeout value expires.
(2,851 Views)
