using fuzzy logic to implement many input to one output
i stdy at university and i required to implementation a fuzzy controller. For example 5 input is to be set and the one value of output.. i blur because i using labview version 8.6, i find for fuzzy pelette is not here.. can someone help me? any example should i stdy? sory, my english is worst..
(2,579 Views)
Hey
You have to install the LabVIEW PID and Fuzzy Logic Toolkit or the LabVIEW Real-Time Module to have the Fuzzy Logic available in the palette. The Fuzzy Logic is installed under the "Control Design and Simulation" Palette. Please talk to your professor and see if you have any of these software available.
Also, notice that in LabVIEW 2009, we have a completely new version of fuzzy that has an interface that much improved. I advice using this version if you can.
Barp - Control, Simulation, RTT and HIL - National Instruments
(2,560 Views)
