using labview from linux
Hey,
I am using labview 8.5 on a linux machine (fedora) and I am trying to use other vi's created in an earlier version of labview (7.1 and 8.2). I know that  it is not supposed to matter and that 8.5 should be able to open these because they are recent enough. However,  I still get error messages whenever I try to use something that's not 8.5. I have opened all these same vi's with labview 8.5 on a windows machine and the whole earlier version thing works fine. So I am wondering if there is a way to update the older vi's to the newer version of labview so that linux won't freak out, or if there is a way to get around the problem in linux. Please help and thanks!
(4,447 Views)
Hi ekarl,
You should be able to open those VIs from within linux using LabVIEW 8.5 as long as they don't have unsupported functions for linux. Can you open them in linux using previous versions of LabVIEW?
If it is only one or two VIs you can post them here and I will convert them. However I would like to find out why you are not able to open them.
Can you open any VIs in 8.5 that were created in previous versions?
Sappster
(4,424 Views)
I might be wrong, but I dont think that Linux supports the use of shared variables or local variables.  If you use either of those it could cause a problem.  Post a vi that isnt working if you can.
(4,420 Views)
I don't have LabVIEW for Linux, but I doubt the second part of that is true. If it is, Ray would absolutely love it. Smiley Very Happy
(4,405 Views)
smercurio is right 🙂
I doubt that the first part is true.  But the 2nd part certainly is!  Using Local Variables could cause a problem.  😉  They are called "race conditions", "headaches", and "total mess".  The worst case is using them to initialize what people perceive as variables at the beginning of a program.  That's because in Labview, the WIRE is the variable!  😉
Seeing the code would also help..
RayR
(4,386 Views)
Just so there's no confusion for others who are reading this: I was referring to the support of shared variables/local variables, while Ray (aka JoeLabVIEW) is talking about the wiseness of using shared variables/local variables.
It is true that shared variables are not fully supported in Linux. See Shared Variable Support in LabVIEW 8.2 for Mac OS X or Linux. However, I never heard of local variables not being supported in Linux, since they reference front panel objects.
(4,374 Views)
I agree, shared variables are not supported but I was wrong about the local variables (but use them carefully!).  Sorry for the confusion.
(4,367 Views)
