using labview to control PXI with cRIO modules
Hi, anyone got any examples/reference material/vi's to do this and where to start as a basis. Just need a starting point e.g. pxi vi's etc.
Stu
(2,813 Views)
What exactly are you trying to do? What does your system look like?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,809 Views)
Hi, initially datalogging and data display. Using using cRIO modules e.g. analog input/output through a PXI express.
(2,803 Views)
Hi Stu,
Could you describe what exactly you would like to achieve in as much detail as possible? Things like which modules you have, which PXI cards you have, how are expecting to connect your C series modules to the PXI cards, how it should all work together, etc.
By understanding exactly what you want to achieve, we'll be able to offer an appropriate response.
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
(2,784 Views)
I am an intern who has just been handed a project where I need to setup a simulator using a real time module and a CRIO/PXI1050 chassis. I have some experience as a student in using the LABView (i own a My DAQ student version) instrument & software but I am completely new to the above instruments and I wanted to ask you if you could give me some reference where I can get a handle of the basics like architecture, wiring, how it works etc.
Also, I know that NI has some tutors available but the thing is that I have to be at work all week so a reference pdf or something might be perfect to get me started here.
Thank you.
(2,575 Views)
