using labview version 8 can application.exe be created for linux platform?
hi
Good morning..
I have been creating GUI for windows platform using Labview version 8.
Is it possible to create application.exe for linux platform...are there any settings that could be changed to make it work on linux platform ? or it will directly work when installer is installed in linux platform...
waiting in anticipation...
Thanx  ....
Regards
yogan
(2,613 Views)
You must setup a machine with Linux and install LabVIEW for Linux on this machine.
If you haven't used any Windows technics you can copy the VIs from the Windows machine to the Linux machine, open LabVIEW on the Linux machine and create the application.
There is no setting on any platform of LabVIEW to generate applications and/or installers for other platforms.
Message Edited by waldemar.hersacher on 08-05-2008 08:22 AM
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,612 Views)
