using list
hello,
I have some toubles using M list , i don't know if there is a better way
to have for example rows 0,1,2 editable from user and 3,5 let him choosing in a menu.
i have probleme if i write in cell 2 for example and just after clicking in a row menu, my previous entry is not recorded
in table.  i 'm forced to click elsewhere or pressing enter key before...
also how can i activate tab fonction to pass a column to other ?
Best regards
Tinnitus
here a vi
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(4,115 Views)
Can you include your sub_selection_data.vi?
I just did a quick overview of the code (not fully read it).  It's well done and just needs a bit of cleanup.
I think I understand how you index the state machine based on column selection.
I would like to see the sub-vi to get a better understanding of what's going on.
R
(4,100 Views)
yes i forgot,
(4,094 Views)
hello,
here the full vi in 8.6 with other functions but without influence.
The problem is always the same, is there a way for manual entries to be considerated even if i click on a 'cell menu' just after ?
Best regards
Tinnitus
(4,062 Views)
I will try to look at it today if I get a break during the day.
Unless someone beats me to the punch 😉
(4,055 Views)
