using local variables
trying to use a simple local buffer to get an interger value and use it some where else. any help?
(4,715 Views)
It's hard to give specifics without more information. What is it exactly that you are trying to do?
Mike...
Message Edited by mikeporter on 05-08-2007 10:15 PM
Certified LabVIEW Architect
LabVIEW Champion
(4,710 Views)
Simply Rt Click on the integer & select Create -->> Local Variable, thats it... Use it elsewhere in your program. Smiley Very Happy
- Partha ( CLD until Oct 2027 🙂 )
(4,696 Views)
If you are using a state machine, here is another way to create local variables.  Create a cluster with all local variables that you need.  Wire into a shift register.  Use Unbundle to get the value and Bundle to change the value.  See code below:
Message Edited by tbob on 05-09-2007 11:58 AM
- tbob
Inventor of the WORM Global
(4,664 Views)
In LV the way you get data from one part of a diagram to another is through a wire. If you are contemplating using local variables because the diagram is too large or the wiring is getting too messy, you have a more fundamental problem than how to access a given data value. Your code needs to be redesigned to decompose it onto reusable modules. One of the major causes of instability in a program is the presence of race conditions created by utilizing local variables.
Mike...
LabVIEW Champion
(4,653 Views)
