using matlab for image acquisition and calling in labview
I wanted to know if it is possible to make image acquisition algorithm on matlab and then call it on labview. If it is possible then how to do it?
(2,797 Views)
This seems to be an off-shoot of this: http://forums.ni.com/t5/LabVIEW/image-acquisition-processing-and-display/m-p/1620710
As far as your question is concerned: In general, you can call Matlab code via the Matlab Script Node. The computer will require a full version of Matlab. Other than that, I have no idea what else to say because your question is so vague (a little bit like your other question).
(2,792 Views)
yeah...i know. that'sbecause we are pressurized again to make the image acquisition algorithm. 😞
(2,788 Views)
