using modbus RTU via serial line, EXE not able to communicate
Visa Runtime Library is also embedded while making the exe. file.
Message 11 of 16
(779 Views)
COM1 Is present in VI but that is not working it shows the error 56,
Message 12 of 16
(773 Views)
Hi Wajiddjo,
Is COM1 also present in that other computer?
Is your device connected to the very same COM port?
Are you able to change the COM port in your executable, either by some preferences menu or (atleast) by using an INI file?
Message 13 of 16
(767 Views)
COM 1 shows in every computer but when i open it in my computer, these option are occurred and 4th option (ASRL3::INSTR) working, but when it comes to another PC it does not show any of the below option except COM 1
Message 14 of 16
(762 Views)
Hi Wajiddjo,
those other options seems to come from an Ethernet-To-Serial converter.
Did you install the needed drivers for that converter?
Message 15 of 16
(754 Views)
Yes, I installed the drivers, from the website which was mentioned while purchasing the converter.
Message 16 of 16
(727 Views)
