using pictures
I would like to ask if anyone can give me a summary of the picture function(s) as I would like to learn more about them.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,934 Views)
Hi Harold,
You may need to look here.
This thread is awesome.
- Partha ( CLD until Oct 2027 🙂 )
(3,913 Views)
Thanks for the post it is great:)
now I just need to sit down and practice.....alot....
thanks again
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,892 Views)
I think you asked about the picture functions, meaning, BMP, JPG, PNG functions. They all are present in the functions palette. With LV Help open, I m sure you can learn about them very quickly.
But why I showed you that link is to make you broaden up your horizons about the usage of the Picture Control.
Also, the Picture Ring control can be used to make animations in UIs.
Find out MikeS81's post reg a library of VIs for handling PNG, which he posted sometime ago, not in discussion forums, but in the examples, I think... It uses windows DLL for processing PNG files, if I remember correctly.
(3,886 Views)
Partha are you referring to this thread regarding gif
(3,864 Views)
Hi Mathan,
I think you found out the correct Forums post for me...
But what I meant was the Developer Zone example for GIF like this, posted by Mike Schroder (I think he is only MikeS81 in forums)... I m not able to locate it now...
(3,860 Views)
Mathan,
I meant this link, mentioned by Mike himself, in reply 36 of the thread you posted.
(3,856 Views)
