Looking at what you are saying, it shouldn't be a problem to just create a LabVIEW program that will just stream data to the "file".
I don't personally see a problem, all you need to do is make sure you have the correct file write functions.
Before you start, make sure you are using binary, ASCII file writes, weather you need to be telling the "file" the timing of each output point and how this will effect the reation of the card.
The same applies to reading the file, it is possible to read on the go. (You just need to use the EOF flag for each successful read) and from there you can (as long as you know the data type) convert the data to the appropriate numerical values for analysis.
I would therefore suggest that this is a feasable solution as ong as you are confident that all you need are file write and read functions to control the device.
Please post again if you reqire mnore information
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
