Showing results forĀ
Search instead forĀ
Did you mean:Ā
using "remote panel connection manager" programmatically
A web browser may stablish a connection to my vi or break it. I want to know when these are happened in my program to do suitable tasks.
Thank you for your help.
(3,063 Views)
Hi Soroush
I understand you want to monitor who, is somebody, is connected to your vi.
Ok, that is possible. See attached doc. and see Tools>Application control>property node properties for remote panel).
Hope it helps
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,063 Views)
Hi Alipio,
I'm using Labview 6.1 full version. I guess what you told, was about a different version. true?
I am eager to know if there is any solution for labview version 6.1
I also read the code you sent. but i couldn't make a property node that contains "RemotePanel.ConnToClients".
will you give some explanations?
Thank you very much for your attention and help.
Soroush.
(3,063 Views)
Sorry about that
That solution is for Labview 7.x
I don“have version 6.1
Alipio
(3,063 Views)
