using reentreent vi in RT
Can i use reentreent vi in RT (PXI) coding the RT loop ratwe is 1 sec.Instead of using multiple copies, i am using reenteent vi in RT coding.will it cause any problem in my loop rate
(2,674 Views)
Hi shan,
            Upto my knowledge Multiple instances of reentrant VIs can execute in parallel without interfering with each other.So loop rates does'nt affected.
Thanks as kudos only:)
(2,670 Views)
may using reentreent vi cause any memory allocation problem.How much memory it will take?
(2,665 Views)
Hi shan,
             Re-entrant VI's take up more memory.I think By enabling shared clones,will give you the benefit of reentrancy at a smaller cost in memory and resources.
             Look at Tools >>> Profile >>> Performance and Memory for memory usage.
(2,653 Views)
