using sbRIO evaluation without FPGA module
We are running LV2010 sp1 with the RT module but no FPGA module. This hasn't been an issue with the cRIO units that we've deployed but here's my question:
Is it possible to use the sbRIO evaluation kit hardware (specifically the daughterboard) without the FPGA module? I know scan mode can be sort of shoe-horned on to an unsupported backplane--the 9631--by compiling a blank FPGA .vi [this article: http://digital.ni.com/public.nsf/allkb/122E971F52FD081A86257500007A046C?OpenDocument  ] so after this is accomplished, and my FPGA trial license expires, will I still be able to use the sbRIO-9631 evaluation kit?
(2,747 Views)
Actually we added Support for Scan Engine on sbRIO devices with 2M Gate FPGAs with LabVIEW 2010.
However, the Scan Mode Supports only the on-board analog and digital I/O modules. To access the 110 on-board DIO lines you still need to use LV FPGA.
Christian
(2,735 Views)
