using the keydown option in order to trigger an event
If you have no further questions you should make the solution as solved so that others do not try to help on something that is done.
Also Kudos are always welcome if someone helps you. It is a way to say thank you. Just letting you know since it is your first time here.
Tim
GHSP
Message 11 of 11
(547 Views)
