using usb 6501 to track the position of 6 different stepper motors
yes that gets it to read the digital signal, but then how do I detect the change in direction?
Message 11 of 12
(914 Views)
Save array from previous iteration into shift register. Detect change - it will give you position.
Angular encoders usually have 90 degrees phase shift between 2 channels. So if value change is positive (rising slope) on one channel and second channel is 1, then it is rotating clockwise. Similar with other 3 cases. Look at your signals with 2 channel scope (or at LabVIEW chart) to check it is the case for your encoder. Arrays are small it will not take time to process them, it can be done on the fly.
Message 12 of 12
(900 Views)
