using windows media player in labview
Need to learn how to use Windows Media Player 9 in Labview 6.1 and 7.
(5,310 Views)
tell me what you would like to do with it and I will help you. Do a search on activeX in the examples and you will find how to do it with activeX.
Joe
Joe.
"NOTHING IS EVER EASY"
(5,310 Views)
Allright, I need to know how to load a movie file into a Media Player window embedded on a VI. I also need to know how to play, stop, pause, fast forward, rewind, and I need an example of all. Thanks.
(5,310 Views)
Try this. It loads the media player. hit play movie then select which movie you want to play. this loads the movie into memory and starts playing then when you hit stop vi it stops the vi and the movie.I do not have any movie files to try this with but I tried this with other media and it worked fine
Joe.
(5,310 Views)
