utilisation du tutorial
Je suis en train de me familiariser avec LV grace au tutorial labview proposé par NI et je ne trouve pas les vi qui sont censés se trouver dans la bibliothèque fonctions>>tutorial.
J'utilise la version 8.5. Est-ce qu'il faut télécharger cette bibliothèque? sinon où est-ce qu'elle se trouve?
Merci.
(4,304 Views)
French to English for more and fast responses: I am trying to familiarize myself with the grace LV labview tutorial proposed by NI and I can not find vi which are supposed to be in the library functions>> tutorial. I use version 8.5. Do I need to download this library? otherwise where is she is? Thank you.
Message Edited by Mathan on 05-04-2009 08:09 AM
(4,282 Views)
Bonjour edjo,
There is on NI web site several tutorial on LabVIEW.
Could you be more explicit on the tutorial you are talking about?(Name, URL...)
Regards
(4,259 Views)
The tutorial I'm talking about is tutorial LabVIEW edition of january 1996, serial number 321191A-01 but I realize that it may be too old version of the tutorial for the version I use.
I put the tutorial in attachment
thanks
(4,247 Views)
