value dependent boolean to retain its sense when values would change boolean
I am trying to create a program that has a boolean that is dependent on a value, and that boolean is connected to a case structure that is nested in another case structure, which is nested in a while loop. The boolean is true until the measurement is less than a certain value. Once it is less than that value, I want the boolean to remain false, but the measurement is such that it will change so that the boolean would become true again. Is there anything I can do to keep the boolean false once it becomes false?
(2,580 Views)
Add a shift register to your While loop.
Wire a True boolean constant (from outside the loop) to the input (left-hand) shift register.
Add an AND gate to the While loop.
Wire the input shift register to one input of the AND gate.
Wire your Pass/Fail test to the other side of the AND gate.
Wire the output of the AND gate to two places:
1. The boolean you want to go False and stay False.
2. The output (right-hand) shift register.
The boolean will default to True until your Pass/Fail test fails. From then on, it will be ANDed with False, so it will always be False.
(2,580 Views)
You may need to add some inverters to the diagram as I described it above depending on whether you want to show failures or passes.
See the attached LabView 6.1 example.
(2,580 Views)
