value of a particular cell in table
Dear all,
How to get the value of a particular cell in a table ?
There's an invoke node for setting a cell value . but i cudnt find any node of retrieving a cell value .
Ritesh
Message 1 of 8
(3,373 Views)
Try this. I borrowed it from someone over here. Smiley Tongue
PaulG.
Retired
Message 2 of 8
(3,361 Views)
I dont know but that program didn't seem to Work for me.
Now, i am storing the values of the Table in a String and Using Index Array to retrieve the value of the Cell.
I wrote a program to change the value of a cell on a Left click. The Algorithm seems to be OK, but its not delivering the desired Output.
Could You please have a look at it and let know where the Problem exists ?
Ritesh
Message 3 of 8
(3,330 Views)
hi
as per my knowledge when mouse point is placed on a cell value will not update to that cell because of this u r not getting value in table i have modified ur vi now u can see that value updating after clicking on other cell.
Santhosh M
Message 4 of 8
(3,323 Views)
Hi Santosh,
Its still not giving out the proper result.
Did you run the program on you sytsem ?
regards,
Ritesh
Message 5 of 8
(3,297 Views)
In my example the data type is dbl. Change it to a string value and try it again.
PaulG.
Retired
Message 6 of 8
(3,295 Views)
Hi PaulG,
I got it .
Its working fine now .
Now i am trying to update the value of the table on Left Mouse Click.
I have already posted the VI in my previous post.
Could you pls have a look at it and let me know if you could figure out the problem?
ritesh
Message 7 of 8
(3,292 Views)
Your table is not getting updated because it is outside your loop. I brought it inside the loop. Also, I changed your table control event from "mouse down" to "mouse down?".
PaulG.
Retired
Message 8 of 8
(3,248 Views)
