value out from unfinished loop
Hi!
I have a smaller problem. How do I pass out a boolean value from a whileloop
when the loop is running?
See attached file..
Message 1 of 8
(3,645 Views)
here is file....forgot
Message 2 of 8
(3,638 Views)
Use a local variable !
See your vi, back...
Chilly Charly    (aka CC)
Message 3 of 8
(3,630 Views)
Hello fred,
have a look at the attached file!
Message 4 of 8
(3,628 Views)
Thanks GerdW for correcting my confusion between both booleans...
CC
Message 5 of 8
(3,617 Views)
Hallo!
Ok, Thanks.But..
my real need is this:
In my mainloop that I want running all the time, there is a boolean
or something that starts a parallell loop to the first! I dont want
the second parallell loop to run all the time, only on command!
Is there a way to fix that?
Thanks, Fred
Message 6 of 8
(3,619 Views)
Hello Fred,
just add a case to the 2nd loop. See the attached example.
@cc: I didn't correct your example, we worked in parallel...
Message 7 of 8
(3,610 Views)
"cc: I didn't correct your example, we worked in parallel"
I know, that's why you got 5 stars !:) 🙂
Message 8 of 8
(3,597 Views)
