value test
hi,
How I can test a value for 10 time, that is zero?
(2,680 Views)
can you please elaborate?
Vielleicht auf Deutsch?
Regards
Florian
(2,656 Views)
It depends what you want to do.
Are the values in an array?
Are you reading the value from a port (serial, USB, ethernet / TCP)?
Is the value generated by an algorithm?
The basic answer would be use a While Loop or For Loop (or no loop), but without having enough information on what you want to do, it is impossible to offer any good suggestion.
(2,653 Views)
