values in two columns in Excel
Good morning
I am writing the values to the Excel from 2 sequences, now in the excel it writes one below the other but i like to write in separate columns
(2,867 Views)
Able to get it in separate columns,
The above program is in for loop(say N=10),the header is repeating 10 times,how to avoid this
(2,862 Views)
The simple answer is don't write the header 10 times.Smiley Wink
Since you did not post your code or even mention which function you are using, I have no idea how you are creating this file but the general practice would be to write the header in a separate function from what you are using to write the data.
(2,840 Views)
