variable manager with array
When I use an array as a shared variable, how can I view the whole array with the Variable-Manager?
I only see the first element of the array, but none of the following elements.
I'm using LabVIEW 8.2 though.
Many thanks in advance
(3,196 Views)
Accepted by topic author kein
You can just view the first element, there is no other way in variable manager.
Christian
(3,169 Views)
ok, thank you for your answer. Now I won't lose more time on that.
(3,165 Views)
