variable time multiplot XY chart
Gurus,
I have reached the point in needing some help. Attached is a simulation of what I am doing. The part I need help with is quite clear...
I need to plot 2 XY graphs: data vs a variable time (although in the example it is fixed). One chart has a single plot, the other 2 traces. The graphs have a fixed length, behave like a waveform chart, except it is first in first out.
The graph in the top level VI labelled Total SA is a single trace plot. When running I can right click and select 'clear graph'  and it removes all the data in the buffer.
How can I achieve this with the mutli plot (2 traces)  XY graph labelled Total Mass in the top level VI?
Paul.
Message Edited by Manc Pablo on 09-02-2008 12:25 PM
"When I read about the horrors of drinking, I gave up reading"
(2,703 Views)
Hi Manc Pablo,
Having read through your problem and taken a look at your code I would suggest that you investigate the piece of example code called "XY Graph.vi" in the LabVIEW example finder.  This demonstrates the correct coding practice for plotting two traces on a single graph.
I hope this helps but if not please reply with any problems you are having integrating the example code into your own vi.
Tom
National Instruments UK & Ireland
(2,660 Views)
