variant to data error
hey,
i'm trying to read values from excel to lv.... i found these two example....but there is some source-sink error at the variant to data node...
can some1 plz look thru
also ne suggestions on how to read data to LV from an open excel file to which values are cont appended(by an external program) will b very helpful
Thanx
DiPS
Message Edited by DiPS on 04-01-2007 11:31 PM
ps:reposting with correct attachments
Message Edited by DiPS on 04-01-2007 11:36 PM
(2,801 Views)
Hi DiPS,
I hope you are doing well today! Are you just trying to read from an excel file into LabVIEW? If so, you can search the forums and should be able to find lots of examples which can help you do that. Just search for 'read from excel'. You can also use the 'Read from Spreadsheet.vi' in LabVIEW.
I am not sure if you can read from an excel file that is being continually edited. What exactly are you trying to do?
Message Edited by Adnan Z on 04-03-2007 12:15 PM
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,776 Views)
