vb.net program determine if runtime engine is installed
I have a vb.net application we are distributing and it calls a couple of vi's that I have bundled into a dll.  Obviously we need to have the runtime engine installed on the machines we are deploying this application to.  I was wondering if there was a registry entry or some other way to determine if the runtime engine was already installed on a windows machine.
I know I could build my own installer and set registry keys, however the minimum runtime engine installer works and it is only 28 mb, where the smallest installer I have been able to build is about 140 mb.  So, as I said I am faced with two options, figure out a way to build my own minimum installer or figure out how to determine if the standard NI minimum installer is already install.
I haven't been able to find anything relating to this in my searches.
Eric.
(3,903 Views)
Accepted by topic author erfigge
There may be a more elegant way, but you could always check <Program Files>\National Instruments\Shared\LabVIEW Run-Time\####
EDIT:
Oh I found it by the way (with a little Regedit.exe searching):  HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\LabVIEW Run-Time\####
*where the pound signs represent the version number.
If someone helped you out, please select their post as the solution and/or give them Kudos!
(3,891 Views)
Indeed the registry is the way to go.  Here is a post on LAVA I did a while ago where I use AutoIt to get the different versions of LabVIEW installed (development or just RTE) and then run the appropriate version for the one installed.
http://lavag.org/topic/17803-run-exe-based-on-installed-run-time/
The source code is included so you should be able to understand the registry keys I read to find the versions installed.
(3,878 Views)
Thank you everyone.  Found the registry keys and that is exactly what I was looking for!
(3,874 Views)
