versions of lab view
Hi:
Just a few days ago i put this message:
Hi:
Im trying, to find a way to search, a file stored in different subfolders of a main folder, and copy, i mean i have a VI which makes a folder everyday (the name istoday date, or yesterday date), and inside that folder is a serial1.txt log file, but yesterday (for axample) the same log file (serial1.txt) was generated, how can i search in lab view all of those serial1.txt files?? By putting just in the search field, the main folder name???
And I want to copy each of these serial1.txt, to different paths???
So in this days, i ve working and the file is ready, but this archive just search like this: main directory /2nd directory/ 3rd directory/Files.... I mean if the files is deeper in more subdirectorys, does not work well works for me.
Im working in lab view 8.5 but, when i tried to put the .exe file in the computers where i have to look for my files, sorprise!!! the computers have the version 7 express or somethig like that so i cant use my file. IT Is possible change the version of my file to version 7?????
(2,572 Views)
I don't know if you are still asking the same question in this thread or not. If you are, don't start a new thread.
As far as the exe, all you have to do is install the 8.5 run-time engine on the other PCs. If you had created an installer (something you should always do), the run-time would have been included.
(2,569 Views)
No i dont know how create a installer
can you help me???
(2,566 Views)
Accepted by topic author LKCH9
In the project explorer, right click on Build specifications and select New>Installer. After that, you should be able to follow the instructions in the on-line help.
(2,531 Views)
