vertical scale
Hi, how to create an vertical scale for an altimeter or an airspeed indicator whith LabView ?
Tanks Fred
Message 1 of 10
(4,582 Views)
It appears you've asked this question before. Unfortunately I don't know French, but the gist of it based on Google Translate was that you had a package. What happened with it? This has also come up before. Try looking through the results from a search (also from this search).
Message 2 of 10
(4,554 Views)
Tanks Fred
Can't you just use a numerical indicator? What is giving you a problem?
Cory K
Message 3 of 10
(4,538 Views)
If anything, a dial would probably be more appropriate, since air speed and altimeter indicators are dials. You can slap one together by customizing a LabVIEW control or by creating an XControl. An XControl would probably be more suitable for an altimeter since has a numeric dial inside of the dial that updates as the dial rotates. In the end it really depends on how realistic you need it to be.
Message 4 of 10
(4,535 Views)
Accepted by topic author fred83
I actually asked this question already, but without any response.
I built a Glass Cockpit with ActiveX GMS (Global Majic) and a gyroscopes, pressure sensors, but I would also like to put an vertical scale altimeter and one vertical scale airspeed.
I'm newby with LabView, can you help me ?  Lock this on my wbsite
I'm sorry for my english speack
My Project:
Thank you
Fred
Message 5 of 10
(4,528 Views)
You know, I've tried customizing controls and indicators before,
only to realize that I'm not an artist, by any means :smileysad:
Cory K
Message 6 of 10
(4,527 Views)
I'm confused. If you have the ActiveX controls, then what are you trying to do in LabVIEW? Are you trying to replace the ActiveX controls with pure LabVIEW ones?
Message 7 of 10
(4,519 Views)
To save space, I wanted to replace the altimeter and airspeed in ActiveX, with an control built with labview.
See this exemple.
Fred
Message 8 of 10
(4,516 Views)
Well, that's pretty complicated. You may be able to do this with custom controls or an XControl, but it would take a lot of work, even for experienced LabVIEW programmers. The LabVIEW Help has instructions on how to create custom controls. You can take a look at the example on creating custom controls for chess pieces. XControls are more complicated, but are a lot more powerful. There's a thermometer example that you can take a look it.
Message 9 of 10
(4,511 Views)
Tanks smercurio_fc, i loock this exemples.
Fred
Message 10 of 10
(4,489 Views)
