vertical scroll bar
hi,i am new to LabVIEW..so i have small doubt.
In LabVIEW 7.1 have a Table with vertical scroll bars. i take output of measurements in table.  When the table is  full, the vertical scroll bar starts to move "up" the table. Is there a way to keep the srcoll bar at the bottom, so that the last line is always visible?
(3,375 Views)
On this post you have your answer http://forums.ni.com/ni/board/message?board.id=170&message.id=154507&requireLogin=False
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,370 Views)
(3,367 Views)
You can create a property node  Property>Index Values that controls the upper left cell displayed in the table.
Subtract the # of rows displayed in the front panel from the # of rows in the table to figure out which row value to write.  You can use property node Property>Number of Rows to determine how many rows in table.
Ooops.  I'm a bit slow typing today.  Smiley Very Happy
Message Edited by centerbolt on 03-20-2008 11:39 AM
(3,365 Views)
thank you for all your responses...  benjaminR, vsh, centerbolt
(3,339 Views)
