vertical slide graduated color scale
Hi all-
Can the stock vertical slide VI's and tank Vi's be configured to show a graduated color fill. Like the classic blue to yellow to red. Where red is filled?
Thanks!
(3,050 Views)
Yes.
You will have to use the Property Node to set the color based on percentage fill. I don't know the exact formula for the colors you seek, but attached is a quick example of a changing Fill color based on fill level.
Hope it helps..
JLV
(3,050 Views)
If a smooth transition is needed, here is a VI that can show how to do the tranision colors.
(3,050 Views)
Jeremy,
You're the man.
Nice example... I know I couldn't whip up something in less than 5 min..
I hope Silverpigeon likes it
:0)
JLV
(3,050 Views)
