very small value
I got simulation and a value is so small, i.e 50nV (10^-9) or something like that, but only what I see is only 0.00 and that the only positive or negative sign is chaning in time, but the value is not changing. How to see very small value? What is wrong?
Thank for help
(4,777 Views)
Accepted by crossrulz
Hi Jack,
use a suitable formatting for the numeric indicator.
You could use "scientific" or "SI" formatting, like %e, %g or %p…
(4,775 Views)
Which numberi indicator? Can you explain correctly. Where I can find it.
(4,772 Views)
Hi Jack,
Where do you "see" this value of 0.00?
Probably in a numeric indicator!
Change the formatting of this indicator to suit your needs!
I used the "official" LabVIEW wording of "numeric indicator". You can lookup this in the LabVIEW help!
And I think I explained the solution "correctly"…
General recommendation:
When you have LabVIEW specific questions it always helps to attach a VI (or snippet) to explain the problem you have. We will quickly answer, most probably with a VI showing the solution to your question!
(4,763 Views)
I get. Thanks
(4,761 Views)
Yes, the value is in numeric indicator, but klicked right-mouse and I got.
(4,757 Views)
I guess you could've just resized the control until you can see enough zeros?
Bill
CLD
(Mid-Level minion.)
(4,701 Views)
