vi memory usage vs size on disk
I have a VI whose "Memory Usage" property shows Total memory usage of 157.9k, but total VI size on disk of 1353.2k.
Why would that be?
32-bit LabVIEW 2016 f2 patch
64-bit Windows 7
Brian Smith
Advanced Light Source
Lawrence Berkeley National Laboratory
(3,572 Views)
Hi Smith,
lots of images on the front panel?
For more detailed analysis you should attach your VI!
(3,529 Views)
As Gerd says, pictures would explain it. The Total Size is the sum of code node and objects, not total memory size.
Personally i'm more surprised that my empty test diagram has 2,7k block objects and 4,3k front panel objects, but i suspect that front panel picture results in some hidden code.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,518 Views)
Ah, sorry, no pictures at all.  See attached VI.
I did figure it out, though.  There is a reference to an IMAQ image as an input and one as an output.
When I deleted those, the disk usage went down to 33k.
Why would they take up disk space at all?
Brian Smith
(3,493 Views)
