vi memory usage
Not having much experience in I wondered if you agree with this:
VI Memory Usage
LabVIEW handles many of the details that you must handle in a text-based programming language. One of the main challenges of a text-based language is memory usage. In a text-based language, you, the programmer, have to take care of allocating memory before you use it and deallocating it when you finish. You also must be careful not to write past the end of the memory you allocated in the first place. Failure to allocate memory or to allocate enough memory is one of the biggest mistakes programmers make in text-based languages. Inadequate memory allocation is also a difficult problem to debug.
The dataflow paradigm for LabVIEW removes much of the difficulty of managing memory. In LabVIEW, you do not allocate variables, nor assign values to and from them. Instead, you create a block diagram with connections representing the transition of data.
Functions that generate data take care of allocating the storage for that data. When data is no longer being used, the associated memory is deallocated. When you add new information to an array or a string, enough memory is automatically allocated to manage the new information.
This automatic memory handling is one of the chief benefits of LabVIEW. However, because it is automatic, you have less control of when it happens. If your program works with large sets of data, it is important to have some understanding of when memory allocation takes place. An understanding of the principles involved can result in programs with significantly smaller memory requirements. Also, an understanding of how to minimize memory usage also can help to increase VI execution speeds, because memory allocation and copying data can take a considerable amount of time.
(2,947 Views)
Yes. This is right. In many text based languages you have to deal with memory allocation and deallocation for which you will not find a counterpart in LabVIEW.
Regards, Guenter
(2,944 Views)
