vi not executable
hello,
in the attachement you can find a vi which doesn't show any wiring error. but it is not executable.
can anyone help me?
thanks
markus
(3,545 Views)
can you post your vi?
Gaurav k
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,542 Views)
(3,535 Views)
How u saying your VI is not Executable.
you are not got the expected results or the VI is not executing after run button is pressed.Smiley Wink
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,517 Views)
I cannot run the vi. theres a broken arraw. but theres no error indicated in the error window.
Markus
(3,515 Views)
In the error list read the details.
Balaji PK (CLA)
(3,512 Views)
