vi problem
      Can anyone tell me what happened to my vi.On the front panel I'm gettig only the hand tool.I'm not able to move the objects on the front panel.The front panel is appearing like when it is in Run mode.I've attached my vi here.plz help me out.
kiranmayi
Message 1 of 8
(4,583 Views)
sorry the attached vi is here
kiranmayi
Message 2 of 8
(4,582 Views)
I open your VI with no problem (but I don't have report generation addon) and no problem with tools.
Perhaps a solution is that you copy your diagramm and put it in a new VI, when I had such problem it always resolved it like this to not loose time perhaps can work for you too.
Or problem with addon ?
Try the solution and if not working someone else will give you aanother solution
Regards
Greg S.
CNRS
LV 7.1 8.2 8.6 2009 2011 2012 2013 2014
LPMC - CNRS
N'oubliez pas de complimenter cela fait toujours plaisir.
Message 3 of 8
(4,577 Views)
Hi gpsrt,
i can't open your vi at the moment, but maybe you switched to the hand tool. Press shift an right click to change the selection.
Hope it helps.
Mike
Message 4 of 8
(4,575 Views)
Change to edit mode (CTRL-M on Windows)
Ton
My LabVIEW Ideas
Message 5 of 8
(4,568 Views)
Kiranmayi,
I guess you are on the wrong selection tool .
Just make sure you have selected the tool bar
shift+right click gives the options to select
or get the VI to edit mode (ctrl+m)
Sundar.
Message Edited by SUNDAR.N on 23-50-2009 02:50 AM
Message 6 of 8
(4,566 Views)
Message 7 of 8
(4,565 Views)
Thank you very much.It was in the RUN mode...Now I changed it to edit mode...my problem got solved
kiranmayi
Message 8 of 8
(4,552 Views)
