vi program
It is old program with version 7.1 and I can not find the person who did it?
I want to ask you who can I attach big file with many vi?
thanks
Message 11 of 14
(999 Views)
In that case disable that vi and run it and check what are the probelms and errors you are facing so then step by step feed the values that is required to run the code. Try searching any document that has information about that vi.
Message 12 of 14
(996 Views)
this is big vi, how can I attach big file here or send it with e-mail?
Message 13 of 14
(993 Views)
No don't do any thing just run it in your machine and try to populate the variables that the vi requires. The best way is debug yourself and post if you have any query on anything. Debugging is the thing that will show you as a good programmer. good luck
Message 14 of 14
(991 Views)
