vi reference exe is not working
Please any one solve this. In my application application.exe will ask for the vi to execute. I suppose to give defects_feature_information.vi in that path. If that defect_feature_information.vi path is selected from folder its not showing any error.Executing fine. Problem : I builded my application along with defects_feature_information.vi as always included. So I suppose to choose path as H:/my project/Application.exe/Defects_Feature_Information.vi . In this case it shows error. Please anyone help me out. I have included my exe and VI. Note: ProgOpenaVI LV 8.0.vi is top level vi
(2,559 Views)
Normal file path and EXE file path is different. You have to see some documents that can help you build file path in EXE.
Or do one think just create a indicator on path and check what wrong in path......
Its definately different from the actual path
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,547 Views)
If you don't have any defined need to call the vi dynamically then you can use the static vi reference, so that the vi will automatically included into the build.
(2,539 Views)
Accepted by topic author Anitha_Shanmuganathan
Hi anitha,
                                  Can you please elobrate what is actually happening.
Do 1 thing use one indicator to see the path it is taking when you are building exe file.
Use application directory instead of absolute path & that additional SubVI should be inside exe folder than the path of SubVI should be application directory \ folder name of SubVI.
Try this
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,531 Views)
