vi scripting
Hi All,
Is it possible to use one of the Instrument drivers under Instrument I/O using VI Scripting?
Paul
(4,287 Views)
What do you mean by "use one of the driver".? Please explain a bit more about what you are trying to do
(4,223 Views)
What I am trying to say is to use one of the function of Instrument driver using vi scripting. For example one of the function of instrument driver is "OPEN CARDS", is it possible to call it directly using VI SCRIPTING?
(4,219 Views)
As far I know you cannot do that (correct me if I am wrong). That is the command to the driver which you cannot transfer using VI scripting/VI server directly. Generally VI scripting is used for code automation and other things. You can find properties in VI server to access the settings of your driver. What driver are we talking about?
(4,194 Views)
I am trying to make a vi to call directly the function of Pickering PILPXI Driver.
(4,186 Views)
