vi to in run mode
I am not sure why vi  go in to run mode automatically! I am not sure it is with some option i unknownly  ticked or bad link ! Is there any option in LV when makes vi run when open although it is not a application?
(2,398 Views)
Accepted by topic author ssnp
There is an option in the property dialog (Execution section) that is called "run when opened", if this option is ticked.... well, it does what it says.
So open the VI, stop it, hit "ctrl + i" to open the VI properties, chose "Execution" in the dropdown menu and see if this option is enabled, if so untick the box.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,397 Views)
