view share clone reentrant
When I do a share clone for reentrant with debug option turned on but when I ran the caller VI, I can not see any traces during runtime to this shared clone. How do I do that?  For preallocated clone, it's pretty easy but I'm not sure why am I not seeing anything in shared mode.  I even tried ctrl + m but no avail.  Could someone please tell me if there is a way to view this in debug mode.  Thanks.
Message Edited by lavalava on 02-04-2010 12:30 PM
(3,029 Views)
You need to open the instance of the VI and not a clone of the instance.  The easiest way I've found is to open the vi from the Heirarchy window and not from the block diagram that contains it.
(3,019 Views)
Hmm.  How do you open the instance of a shared clone VI buried 4 levels down below?  I've tried View->VI Hierachy, Class Hierachy but no avail?
(2,994 Views)
From the Vi hEIRACHY WINDOW  Right-click
(2,986 Views)
