viewing the logged front panel data
I'm trying to figure out how to read the front panel. When selecting 0perate>>Data Logging>>Retrieve data, retrieval Toolbar will appear and the hightlighted number will be similar to this format:
'[0..0] 6/22/00 5:26:55PM.320'
What is the ".320"?
(2,760 Views)
Just a guess, but I'd say right off hand that it's the fractional seconds. If a VI is running very fast it's possible for it to iterate faster than once per second. The result would be several samples with the same timestamp.
Including the fractional seconds allows the software to distinguish between closely spaced runs.
Mike...
PS: the "PM" is in a wierd place, I'd report it to NI as a bug...
Certified LabVIEW Architect
LabVIEW Champion
(2,760 Views)
When I'm getting data very fast, there are only 2 rages (2 records, the time difference b/t the 2 ranges is 4s) when retrieve, where are the rest of the data?
(2,760 Views)
