virtual switching to connect 2 Digital outputs
I am using FPGA and need two digital I/O to link (act as a switch) for  a couple of seconds then release.  lets say pins 1 and 2
Can anyone advise how I get them to join virtally so the outputs of the two channels (pins 1 & 2) are connected. I do not want any voltage on the lines.
More info: Using NI 9403 modules with CRIO 9148
(2,944 Views)
Hi hawkstringer,
Just trying to understand what is it exactly that you wish to do? Are you intending to connect the pins internally ( within the FPGA) or externally?
Also, Is there any particular reason as to why you would like to do this?
Shazil M.
CLAD
National Instruments UK & Ireland
(2,877 Views)
i have discovered it is not possible to achieve physcial trunking with logical links.
(2,863 Views)
