visa crash
I've got a problem that i Can't solve yet.. I'm Using the VISA resource name to communicate with my GPIB Devices on the GPIB bus. I've made a program that reads a couple of value's from 2 HP34401 multimeters. On this computer it works fine, but when I use the program om a Dell Optiplex GX110 my VISA resource box crashed.
I can hover with my mouse over it for a couple of time's but after 3 or 4 time's it just crashes. My resourcebox is filled with 2 HP34401 and the COM1 and LPT port. But on the other computer the LPT and the comport are assignt with:
ASRL1:INSTR
ASRL2:INSTR
I've used the NI-MAX program that can scan for GPIB devices and also there I can see the strange definition of the COM and LPT port. My problem looks a bit like this:
[url]http://forums.ni.com/ni/board/message?board.id=140&message.id=3047&requireLogin=False[/url]
I have a normal National Instruments GPIB PCI controller in my computer and the same card is used within the GX110. The weird part of it that I Can communicate via NI-MAX (Just sending query commando's). The problem has to be the VISA session.
Can someone give me a hint or a solution ?
Thanx!
Press "F" to format your disk, or "F" to cancel.
(3,503 Views)
Which version of NI-VISA an LabVIEW do you use? There are know issues with LabVIEW 6.0 and the VISA Resource name which makes LabVIEW crash.
The ASRL1:INSTR and ASRL2:INSTR are the Low Level VISA resource names of the COM1 and COM2, usualt the LPT is ASRL10:INSTR.
Hope this helps
Regards
Karsten
(3,486 Views)
I'm using Labview version 6.0.2 and NI-MAX 2.0.3.6 . Is it possible that this versions have these problems? Are there some kind of hot-fixes for this problem?
(3,479 Views)
I would suggest to update your VISA driver to the latest version. You can download this driver here
Download the "NI-VISA Version 3.2 for Windows 2000/NT/XP--Full, LabVIEW RT (Realtime), and RTX support"
Uninstall the current version on your PC through add/remove programs and install the new driver which also will update your MAX version. Try it again after the installation.
Best Regards,
Rik
Rik Prins, CLA, CLED
Software Development Engineer
(3,452 Views)
