visa exclusive lock
I am not having luck opening a com port with the exclusive lock selected in visa.  I am trying to prevent multiple instances of my labview code from accessing the same com port.  I selected exclusive lock when opening the com port visa session then leave thje session open for use in the first application, then I open the same com resource from a second labview session expecting to not be able to open communication since the resource was susposed to be exclusivly locked, but the open visa returns with no errors.  How do I get the exclusive lock to work.  Did I miss something?  Using LV 8.5.1 and the latest visa and Max.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,854 Views)
There is alot of documentation and examples of how to use the exclusive lock feature in the NI VISA Help.
(4,829 Views)
I did not really find a good example in the help file.
Attached you can find two identical vi's (LV2011), I can run them simultanously without getting an error... What did I do wrong?
(4,446 Views)
Didn't you look at the example that comes with LabVIEW (Locking.vi)? Set the Duplicate Session input to True and see if you get an error.
(4,440 Views)
duplicate session = TRUE  , works fine!
Thanks!
(4,421 Views)
